Find you slop first. Look at the tubes for LCa in k bar. Welds could be broken. Found that a few times. Can't recall if that caused slop or instability.
If Oem look isn't a must, look into that bottom bearing kit somebody was selling for below pitman. I tend to think you'll find the issue someplace along the way.
Can't answer about the ratio.
I want my fair share
