You guys and your centering rings, properly nut installation is what centers the wheel on any application. Did old Volkswagens have centering rings ? Pontiac's with 8 lug wheels? how about semi trailers with lugs to hold the wheels on. If you don't know how to properly install and tighten lug nuts to the proper torque ,read up on it or ride the bus .
It all depends on how the wheel/hub is designed, hub centric or lug centric.
30 years ago, most semi trucks and trailers were lug centric, now most are hub centric.
Dodge D350's were lug centric till '93, they went hub centric in '94.
I'll take hub over lug centric.
