I have acquired two Carter AVS Carburetors. One is a M7 440 1S. The aluminum tag says 440 1S 349 701. The other carburetor has a base stamp number D5 463 SA. I also have a Holley List #3310-3 1947. I believe these fit Mopars. I was hoping to get some help with identifying which cars and engines they fit. I'm new to the list and look forward to the knowledge base that obviously you guys have here. I appreciate your help. Thanks, Ross
