I made a map of the floor tubing when it was poured and I can be with 1" of any tubing.. well worth the time to do it
Ditto I generated mine using an OST program and then installed it per design. 4 runs of 300' pex and when it was finished I was within 2' on the length of each run. I should be able to locate them easily if I need too...
