Check your spark plugs to verify the meter isn't being fooled.
Yes, with a 4 bbl, 2 jet sizes is typical change.
On the primaries, or in your case the center carb, jet change should effect high speed cruise AFRs. High speed = Interstate speeds, around 60 mph and up depending on gearing and incline.
