I shifted at or above 7000 RPM after testing a bunch different shift RPM shruggy
I dyno tested that motor several different times on several different engine dynos, two different DTS and s Studka dyno, that motor made peak HP at 5500 and 5600 RPM with the six pack and it made peak torque at 4500 and 4600 RPM, depending on which dyno shruggy
I tried shifting it at 5500 RPM and then 6000 RPM, it ran faster at 6000 RPM so I then tried 6500, then 7000 and then 7500 RPM, it ran quicker and faster the higher I shifted that stupid motor confused I got scared of it above 7500 RPM so I decided 7000 to 7300 RPM was good enough for me thumbs It would repeat ET real well at those RPMs thumbs
That was a good car, lots of fun, especially on the street devil whistling grin
