What's the usual eng.oil leaks,the seconed one I looked at the bottom of the oil pan was wet,they had washed off the eng.so I couldn't tell if it was coming from up above V/C gaskets,oil sending unit was good,do they have head gasket leaks or could it be from the pan gasket, possibly the oil drain plug seal but it was too wet all around.
