Originally Posted By Supercuda
Originally Posted By crlush
Aluminum fuel line works good as long as it clamped with a good rubber lined clamp and is not rubbing on anything. I used it once and where it passed thru the frame it touched and probably vibration and hitting bumps it rubbed thru and leaked. After that i changed to braided line.
This is true of any fuel line, just aluminum will probably rub thru quicker than steel or braided line.
I couldn't believe how fast it rubbed thru, just lucky it rubbed thru in a spot where there was no high heat or over the exhaust.
