Originally Posted By UCUDANT
If only being used as a vent, or return line can aluminum fuel line be clamped to using standard rubber fuel line and hose clamps?
Yes & it'll do OK as a main fuel line in that capacity also. it work hardens then cracks much easier from movement so it must be clamped securely with shorter increments inbetween the clamps.
