Make sure the throttle shaft bushings are not worn out in the base plate. BBD's are notorious for that and it will drive you crazy trying to tune it. It will run fine until you come to a stop, then it will die, start right back up and run fine until you stop again.
"Everybody funny, now you funny too."
