Are the EZ heads standard port or MW port? If they are not MW port then you might consider opening them up to MW port and using a MW size intake. I'd recommend the Super Victor if you can fit it under your hood.
If you don't want to open the heads up to MW size then I'd use the Mopar Performance M1 4500 intake.
