Not if you used a shim and not a full thickness washer. Common practice when assembling certain items that only have 1 proper alignment. Absolutely nothing wrong with this approach.
Also, common practice to hit the torque and add more till castle nut alignment is reached, since this is never more than 1/6th of a turn. Also another acceptable solution with absolutely nothing wrong
Both solutions would be acceptable.
**Photobucket sucks**
