I had to replace a set on a 440 I used to own. They were used with a mild 238@.050/.555 street roller and this what a mess they made...The springs were off and probably lash too, but still what a mess. Day one of car ownership at that.
I would not use these rockers with a stock hydraulic cam
Dang Tony!!!
Don't feel bad....... But I got a pretty good chuckle out of that pic
Don't worry Dwayne, I can laugh now too! I kid you not, I picked up the car (70 Superbee), brought it home from Ohio, took the family out for a drive to show off my new toy - and all of a sudden lots of loud sounds from under the hood. Turned out to be a good car, but I really thought I had been taken. Picked up a set of Hughes rockers and correct valve springs, replaced a valve, and never had another issue. Previous owner helped with the cost too, so that was good.
Still, will never touch a cheap rocker - ever again. Ill use stock stamped before I would touch that garbage.
