It's pretty well known now that with some of the BFG radial ta's the white letter turns brown so they need to be boycotted until the problem is solved. One of my tires letters looks awfull brown and couple others are ivory.
Yep, I'm in the same boat. None of the various solutions suggested here on Moparts have corrected the situation. It's definitely in the compound. So, if you do buy BFG, I'd recommend buying local and understanding the warranty. Make sure they will replace them, if they turn brown. That way, you're covered, even though it's a pain to have to get it done.
I ordered mine from Amazon using points and there's really no way to get them warrantied, especially with shipping costs. Keep that in mind on any tire you order online. I'm not saying don't order online, just understand the ramifications if there's an issue.
