Code is P0152 2/1 is the only code that shows up. The OD switch on the dash is off and when I push the button the light comes on but the OD does not work. Feels like the converter is locking up. When it shifts into 3rd and I maintain a speed in the 50-60 mph range I can see a slight drop in RPM which I believe is the converter locking up.
