Thanks for the feedback. Would have figured the temp sensor was in before paint, but easy enough to remove now.
For the negative cable, agree on the throttle bracket? If yes, over or under the bracket? Over goes towards the water pump housing and under goes up towards the valve cover. I tried both ways and both look good. The lug end fits fine either way.
Oh and then the negative ground strap on passenger rear. I would think this is installed before paint as well. Need to find that cable in my stash.....
Amazing, all the photos I have taken over the years, you would think I could get a consensus on these things. Every engine compartment looks different now that I study them.
I do have a question, do you have the console tach? If so that wire coming out of the fire wall withe the gray female spade, where does that go?
