Sorry, I know this has been covered at some time, but I just cant find it via searching. Wish I would have bookmarked it.
I am trying to assemble what needs to be on the engine for painting on my '68 383 Dart. I need some reference photos of what is correct. Hoping Rhino comes to the rescue.
Passenger side engine mount bracket and rubber, engine color? No - Black
Drivers side engine mount bracket and rubber, black? Yes - same as other mount
Dipstick tube, bare? Since it is bolted to the rear bracket mount, I am thinking the tube may be not painted?
Fuel pump, engine color? Yes
Temp sender not painted,
oil pressure switch - only if it is the small non oil pressure gauge sender...if it is the small one, mask off the terminal area before engine painting.
Anything else bolt on that needs to be on before paint?
Exhaust manifolds.....spark plugs (masked off)
Thanks!
