I believe you recently suffered a failure on an engine, my bet is you aren't gonna replace the pistons if they inspect good, so you are going to build/reassemble an engine with used pistons.
My engine will be getting new pistons. I'll go completely through it to raise the compression and get the most out of it.
I don't like combining used pistons in used bores they've never met. To me it seems similar to mixing used lifters on a used cam.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
