I smoothed out the engine bay and epoxy primed it, soon after the Hemi was dropped in for mock-up.
Soon after, the sawzall met the car to make room for the T56 Magnum. Keeping torsion bars requires pretty significant reinforcement to that area to ensure structural integrity.
I did some high level blocking on the car to see what I had to work with. The car had been painted yellow many, many times!
The trunk was in need of serious work. I replace the floor, trunk extensions, tank supports and the rear rails completely.
The interior was treated to epoxy primer, single stage Lemon Twist, topcoated with tinted RaptorLiner [bedliner] for noise reduction, heat reduction and some durability in the trunk.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
