I have two steel lines that fit the outlets, bend them around to dump into the reservoir. Install M/C, put on bleed lines, put in fluid, slowly work pedal to "bench bleed", remove bleed lines one at a time, installing regular brakes lines and wheel bleed from there.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
