Is it possible to turn down the OD retainer to fit a 4.35 bearing hole when the trans has a 308 front bearing ?? I know it's possible to take the 5.125 retainer down to 4.80 , but to 4.35 ???
Diplomat440 is right, you'll be into the bolt holes, won't work. Maybe a small block scattershield would take the big bearing retainer (308 bearing, not OD)? shruggy
jess
Yeah, it's hopped up to over 160...
