Originally Posted By Quicksilver440
Yes...I believe an 89-91 v6 4 speed bell is what your looking for. It will bolt to any LA small block. As I just discovered...you will need an 11" 143 tooth flywheel to make it work. And that bell uses a hydraulic clutch.
Is that the bellhousing I sold you ?? I didn't realized that ... blush
running up my post count some more .
