I discovered that my stock gas tank will not fit due to the rear end assembly I used. Couldn't find one, so I built one from scratch. My first attempt and I think it turned out very good. I welded some baffles inside to stop the fuel gauge from fluctuating too much. It fits nice and looks good installed. Only problem is ,it only holds about 12 gallons.
