I tried everything previously mentioned (except streach the springs) and I could not get rid of the off-idle dead spot. I even tried a new 800cfm after giving ip on the 750cfm. I also have a low vacuum cam that makes it worse in my 440. The only fix for mine was a different brand carb.
