I changed the rods (smallest diameter that I had first and no change or big change that I could notice
I drilled out the nozzles to .041 next and that made a difference
I changed the springs to the weakest springs , made it worse (I guess that seemed to hold them down in the jets longer so maybe a lean condition
I change back to the strongest springs and that was better
I drilled out the nozzles to .045 and that helped a lot
I ordered a marine accelerator pump as I read where that makes a difference p/n is 1468 but it is still on the way here and I have not installed it
I guess it was a all around lean condition , the floats were fine and were at 7/16
