Got a new egt monitor today, directions recommend installing sensors on the 2 hottest exhaust tubes at idle, are the front 2 usually the hottest? Not sure that's the best arrangement, in event something else is causing a cylinder being slightly lean. It seems the last time I tuned the temps varied lots.
Appreciate all input.
