Do your self a favor and throw it in the trash and order an MSD - the firecore/Summit/Jegs are junk!
I'm starting to believe you are correct,I'm having some Firecore issues of my own.
Can I ask what kind of issues are you having with yours? Just wanting a heads up. Mine seems to be fine. But its just a street car and doesn't get driven much.
Barry, been fighting a no spark issue for quite some time, I have 12 volts to the coil in the run position and about 10 cranking, new coil, new motherboard, good ground, every thing sees to check out, just doesn't work. I have it in the back of my head that it's something I'm doing wrong but I'm at a loss.
