Originally Posted By Cab_Burge
Who makes and sells the 572-13 heads and what block and bore size will they work on? How well do they flow and what size valves are in them? help
they dont flow much better than a -1 and need 4.5 bore....can have larger port volume than -1 when fully ported guess thats the advantage with a bigger cube motor.
