That is a really slick set up and it looks like it can be disassembled. Curious how you choose your pick up points. Did you solely go off of measurements from the book or the actual car to determine it will be perfectly square and level.
I went off of the frame specs as provided by Ma Mopar. I knew I was going to cut the floor, trunk and quarters off and didn't want the car to boogie around and as the car was welded crooked from the factory (imagine that) I thought it best to start where it was
supposed to be.
