If the drain holes are standard (they should be, they are used in the alignment drawings), you can put tapered pins on the tops so they self-align.
how about no way,no how?
just for instance
68,69,70 bbody the holes are different for each year.
i didn't even get to the dodge/plymouth differences in the same year yet
amd saying that about rails shows they don't know squat about replacing mopar metal
why would they even try it to begin with???
they must be learning on the job!
(any mopar body guy should know about the rail difference),they should just stick to making it
unless you plan on doing metal replacement for a living, a jig
is a wee bit overkill i would say
