Here is a crazy thought - have you thought about spraying a small shot on it to get the 60ft down some? I know a lot of that is dependent on track prep or the lack thereof. A local LS tuner loves to spray the sbe Ls engines he tunes and with great results. He typically will leave on a 75 shot and spray it the whole pass. You may not want to push the poor cast crank that far though..
