Pulleys aren't awfully hard to find; main thing is getting the right depth, which can also be adjusted with spacers. You might search "Mopar pulley" on Ebay, as I've done. Water pump pulleys seem to be interchangeable between all Mopars as far as bolt pattern. Another measurement that matters is where the OD is measured: at the base of the V, or the outer edge.
