Curious though, how many of you reuse the snap rings? Not saying its bad or good, just when you take the time to remove a tranny, and rebuild/repair, do you guys reuse snap rings? arent they fairly cheap to just buy new?
The snap rings on the front clutch spring retainers can't pop off when correctly installed, there are tabs on the retainer to keep the snap ring in place and I've never seen one break.
