Curious though, how many of you reuse the snap rings? Not saying its bad or good, just when you take the time to remove a tranny, and rebuild/repair, do you guys reuse snap rings? arent they fairly cheap to just buy new?
If you use the proper tool to depress the clutch spring retainer, it makes it much easier to remove the snapring.
Free advice and worth every penny... Factory trained Slinky rewinder.........
