A Six pack intake is TALL. if you look at the assembly you will notice it has a drop base. I'd think anything as tall would work as long as you have a drop base. I can tell you a Performer RPM w/ a 1/2 space puts the car throat right up on the hood. What is your application? What is the motor build?
