They make a piston, 51950 that's for a 3.75 stroke, and a .990 pin. Id need to have them make it a 4.290 bore, and Ill just buy the PEP rod from Hughes. That's only 1 change and im there.
Prolly better to run the PEP rod with the .990 pin and the floating pin end anyways.
