Don't mean to hijack, but seems relevant so....on this topic, I have an unported w2 pro dominator (thanks Moar Dave)
I would like to use this intake with my 360-1 245 cnc heads.
I am currently running a port matched Indy 360-3 intake and a Davinci dominator.
Do you guys think I would see any gains by switching to the unported unmatched pro dominator? Assuming it was set up properly of course.
Combo is;
468 ci
12.54-1
Bullet solid roller
360-1 245 rp cnc
727
8" ultimate convertor (5400 stall)
3:91 gear
3000 lb a-body.
Pump gas street strip car.
I doubt it.. if I recall the indy has a larger plenum
which you need for those cubes... you might want to add
a 2" spacer under the carb and see if it picks up for you
