Hi guys, am about to install my intake....super victor going on a small block stroker.
The port on the head is larger vs the port on the intake, sooooo I'm thinking how necessary is it to match? If it was the other way around (manifold port larger than the head) I assume it would be an issue, but the way it is, maybe not so much?
Thanks for any info!
I hate to tell you this because the Super Victor is not a CHEAP intake but they kinda stink with-out some porting work. When I received one in a trade I was very disappointed the first time I stuck it on my flowbench for some testing. At the very least gasket match it.
