Like I mentioned, check with DrDiff if you want to know what is out there as well..he knows the low down on it and can help steer you in which ever direction you might need to go. I'd check with him before XV,etc
Oh, and those kits do look familiar...my front uses a custom billet hub with an off the shelf Holden HSV Commodore rotor. The rear is a shelf kit with 13" rotors from Baer, via Cass
