The overall length is 9.060". Here is one of the straight ones. They are silver colored on the intakes and black on the exhaust, if that makes a difference.
Can someone tell me what motor used these heads? Having a hard time finding any pushrods that match this.
What is the casting numbers on both heads? As you know it should have had solid lifters in any of the pre 1965 letter sereis 300 motors, correct? On that pushrod yuo should be able to find aftermarket replacement pushrods for any RB 413,426W or 440 motor with hydraulic lifters and adjustable pushrods to replace the bent one, or you can send one good one in to Manton, Trend or Smith Bros and they will make you one, two or a set like it
Let us know what you find and do
BTW, one of my old 1958 300D convertables is, or was, in the Carpenter collection. I never own a wege powered one, I missed buying a cherry 1959 E convertable due to draging my feet back in 1964
