Originally Posted By WO23Coronet
Can you measure and see what interence is? I'd try chilling them first and heating the block. If it's to much of an interence fit then carefully flat filing each side and carefully measuring to make sure you take an equal amount of each side would be okay.
What kind of an interference do caps usually have with the block? .002"?
Closer to .001... at .002 your gonna need a press
wave
