This is recordings of the car before I did the coil over strut conversion.. Havent had the opportunity to scale it afterwards, but here is what I got..
LF 773 RF 843 LR 687 RR 683 TOTAL 2986
With Driver and fuel LF 853 RF 883 LR 814 RR 684 TOTAL 3234
Did you change the back at at.. did you measure the front(from the fender opening before and after) you changed things
