Aluminum heads and not taking advantage of them? Sell them and do an RV porting job on a set of closed chambered iron models. Maybe even some 516's :stir: 2500 stall would help. My Maxivan with the 360 was running a 2200 cheapy generic converter, Comp 252* RVcam with 3:21's and was a 6000lb shoe box. I ran a 800TQ or a Mopar '86 model Qjet on an Offy Dual Port intake.
There was a problem with one of the stock heads. A valve cover bolt hole was drilled down into the water passage. Instead of messing with that, I threw my Edelbrock heads at it. They were sitting on the shelf collecting dust.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
