I have a t&d pinion height tool and the clam shell type puller. The puller pulls bearings off in seconds and never hurts them. They both work excellent...
That is a cool puller.....but I have to wonder why all the fuss about pulling bearings. Why not just polish the pinion, spool, what have you, so that the bearings are not a press fit and be done with it. Where does anybody think the bearing is going to GO if it's not pressed on tightly
