Mark changed my 950 over to annular boosters because I was running a low RVP fuel in cold weather. The change to annular boosters picked up a lot of torque down low (20 to 30 ft-lbs) but the carb didn't make anymore power up top.
I'll rerun the tests this summer to see if the torque advantage stays there or if it is a cold weather thing only.
