I believe the answer is the oil leakage is through the rocker. I have paired T&D. My pushrod are restricted to .040". The rockers and pushrod ends look perfect. I put 300 passes on them and they were used when I got them. My lifter bore clearance is .002", bushed with a .100" feed hole Doug
