Ok all you guys that gave me advice. Sorry it has taken so ling to get back,but just got the engine back together and problem solved. So whoever put the engine together before I got it,left the oil galley plug out near the distributor shaft at the rear of the lifter galley. In the meantime it started eating up all mt rod bearings and the crankshaft. I had the crank reground and all new rod's and main's. Put new cam bearings along with new cam and lifters again. Just started it this past weekend and has 80 lbs at cold start and 60 lbs after it got warmed up. Not one bit of lifter noise. Thanks for all the advice on here.
