Originally Posted By bigcar
So if I understand this thread correctly, this "cap" cannot be installed from the top of the engine! It must be installed from the bottom? I am having the same problem, on a 340. No one has been able to figure out why the lifters rattle.
Ok now we are confused. 68 gts said you can put this plug in from the top. Who is correct?
