My 340 rattled when they didn't install that plug but also missed the threaded plug in the galley by the distributor!
That normally ends up with a motor having no oil pressure, epsecially when trying to prime it with a drill motor, don't ask me how I know that now
There be two galley plugs on Mopar SB motors on the drivers side at the rear of the block, the large one one is for access to the smaller one inside in front of the distributor and that one is essential to seal the oil galley passages up on that side
