Your gonna want to to figure the ride height.. basically
the rear of the car... point the engine trans directly at
the pinion with the pinion on that center line... I made
a laser set up that points directly through the pinion
center line... once your done then you roll the pinion down
to get your angle... move the engine to line up on the center
line with the pinion.. your gonna be changing both the pinion
center line and the engine to get the correct location.. I
assume you might use a front motor plate so it might go up or
down to get it all in one plane.. also figure that the higher
the engine is that it will transfer weight easier.. big torque
engines dont need to be high(big wheel stands)
